I'm finished changing my oil and want to add these final thoughts that might help everyone. First, the oil capacity is over 7 quarts, not 6-1/2 quarts like the owners manual says. Yes, I did check the oil with the Titan parked on a level surface, I did start it and let oil get into the filter, and I did allow enough time for all of the oil to find its way back before I measured it again. With this in mind, you may want to buy 3 individual bottles of oil when you buy a case so that you will have enough oil for two oil changes.
Second, If you hear a "cracking" sound when you tighten the oil filler cap, don't worry. The cap has a over tightening protection mechanism just like gas caps.
Third, I like how there is enough room in the engine compartment next to the oil filler cap to be able to lower the bottom of the oil bottle lower than the oil fill opening. This allows for spillproof oil fills.
Last, I really don't know what the purpose of the cover plate is. It doesn't seem to protect or cover anything. I wonder if Titan owners who never go offroad really need it. Could it be left off? If so, it would make oil changes easier and faster.
