Hello to all fellow Titanians,
I have a 2006 Titan with a blown head gasket that I plan on replacing the FlexFuel engine. The problem is these FlexFuel engines are more expensive than the regular ones on the same block. I was wondering if anyone knows if its possible to use a regular engine to swap out the flexfuel one with moving all the sensors from the flex to the regular. I seen some information online about moving the camshaft sensor from the front to the back but Im not sure that is the end of the mods on the engine. I was looking to find out if that is possible to use a regular engine instead of the flexfuel and what needs to be modified to make it work.
Thank you to all for your help
