OK, so I noticed some spotting under my truck when I park. Tonight I crawled under there and there is some fluid splattered in a radius all around the underside of the damn truck...It looks like oil, but I can't figure out if it is or not...the level appears to be OK, but it is literally splattered all over the passenger spindle, alternator, back behind the oil pan on the frame, the passenger cat, you get the idea...it's almost as if the oil pan spurts everywhere when it's under pressure, but I'm under the truck while the gas is being hit and It doesn't seem to...maybe it's a leak and the wind from driving blows it everywhere? I have one of the quick oil drain valves and maybe it's leaking? I may do an early oil change and just pull it out and put the old plug back in and hope for the best...
Here are some pics, any and all suggestions are much appreciated.
