Fog Lamp Kit for 2005 Titan 4x2 SE - Not prewired
1228 Views 15 Replies 8 Participants Last post by  MARKSOWN96
Where can I buy a Fog Lamp Kit for a 2005 Titan 4x2 SE not prewired? I have looked on alot of the postings here and have not found anything yet. Help!
1 - 16 of 16 Posts
If you have a SE it should be prewired. Look up front near the opening for the fog lights, should be a pigtail tape up somewhere near there.
Already did that and unfortunately the prewiring is not there.
You sure you got an SE?
When I was buying my 2005 I had to check because during the switch over , in interior and wheels in mid 2005 some did not come with the prewiring for the foglights , do you have the dark wheels or with the compass in the rearview mirrior? If so you you might be one of those trucks.
Very Strange, I thought all SE's came pre-wired!!
Not to sound naive, but SE is what the paperwork says. No compass in the rear view mirror and forgive my ignorance, but what do you mean by dark wheels?
Look at the rims in bbomars sig above, if you have an SE, your rims should look similar.
Looks like the same wheels
Odd that you don't have the wires! Since you don't, your best bet would probly be to just buy some nice aftermarket lights and install them in the factory locations.
I'll look into that - Thanks for all of your help - this site is great!
Several people on here have just taken out the black inserts and cut them out, so the fog lights have a nice clean look!
So in reference to all this fog light talk, I have a 06 KC SE w/o fogs, it is pre-wired and all...I just wanna know if I can (and how) connect the fogs to the factory harness and just use a switch in one of the blank outs? BTW... I'm nw to TT and already think this site rocks!!!
If you buy the nissan fog light kit, it consists of the lights, and a replacement stalk with the foglight switch built in. Popping in lights and replacing steering wheel stalk takes about 20 minutes, anyone can do it.
Dark wheels should have nothing to do with it, My 05 SE has the dark wheels and it was prewired for the foglights.
I should clarify, I already have a set of aftermarket fogs (that just so happen to fit into the stock foglight locations) but I don't have the complete wire harness for it...so just wondering if I could splice it into the factory foglight harness and just somehow connect a toggle switch, rather than buying the headlight stalk ($85). Thanks though.
1 - 16 of 16 Posts
