There has been a change in the Fog light ki availability!! The Fog Light Kit is available for the SE W/Out Off road package and the XE 4WD only!!
If anyone needs help wiring the factory fog lamps to an XE w/out offroad pkg. let me know. Order the factory fogs from Titanparts1, OEMs fit the best. the wiring is a sinch and when you are done, you can use the lights any time, not just when your low beams are on.Titanparts1 said:There has been a change in the Fog light ki availability!! The Fog Light Kit is available for the SE W/Out Off road package and the XE 4WD only!!
