1 - 20 of 30 Posts
I see for previous trucks a factory fog light kit could be purchased after the fact. I am unable to locate a kit for my 2021 XD SV. Does anyone know if this exists?
I'm taking a chance with this - I am not affiliated in anyway, and mine was delivered tis morning.
It's a fog light kit for a 2019 Sentra. According to the fiches, it's the same part # for the lens/bulb housing. It also comes with a switch and a wiring harness to fit the Sentra.
My truck is a 2021 SV (non XD, not sure if this applies to you for wiring or fitment I checked last night, there is no factory wiring taped or up otherwise around either side of the frame for the fog lights like there where in pre '20 trucks. The included wiring harness may or may not fit. It is Sentra sized after all. The box is actually here already but I have not looked at the harness. I am getting ready to head out for the remainder of the day, it will be tomorrow before I can dive into it. The light assemblies do appear like they will mount up, but again...tomorrow. Worst case from here I think may be buying a new OEM switch if this one doesn't match. And figure out where to get switched power from under the dash, preferably when headlights are on.
You are correct, I still need the correct trim pieces. I need to stick my head under a Sentra when I'm at the dealership tomorrow to see if the lights mount using the existing clips in the blank, or if they used actual screws there.
I was looking at that also. Interested to see what you com up with. I think there is a trim piece you might need
I've been digging around the truck trying to find the wiring behind the bumper. I looked behind the dash and can see a connector taped behind the blanks. I've also seen fuses for the fogs in the fuse box. This leads me to believe that there are connectors hiding somewhere behind the bumper. Atleast the wiring is already there to add the remote locking tailgate.
I have been trying to find the pre-wiring for the fog lights as well on my 2020 SV crew cab 4x4 with no luck. Also saw a connector taped up behind the switch blanks and fog light fuses just like freedomrider.
saw this on YouTube:
On this particular 2021 Titan SV in the video, looks like they installed halogen fog lights on the premium package . Be curious to see how the Sentra fog lights work out, because I was looking to do the exact same thing.
Thanks. Yeah I saw those but I was curious to see if there was a halogen version that would be less expensive and allow me to simply upgrade to LED bulbs. My understanding is if the stock LED versions go out you have to replace the whole assembly instead of just the LED. But on my 2020 I don’t even see fog light connectors unless they‘re tucked away somewhere in some obscure location.
Though these halogen versions on Sentra‘s and other models may just work.
Hello, did the fog lamp from eBay works for your Titan? Iam also looking for a kit but couldn’t find one. Please let me know. Thanks
1 - 20 of 30 Posts
