Buy the set from Nisssan, with correct type of stalk.
All you have to do is run a hot lead into the IPDM and get a single wire into the correct output for Foglights. The only challenge is getting a little pin to fit the outlet. My dealer let me get some out of a variety pack the mechanics use, at no charge. Run a ground wire nearby, like on the fender, near the hood hinge on passenger side. Run the 2 wires (inside some loom) down to the lights and buy the connectors from the GM/Chevy dealer to finish off your own harness. It is a PT-120 or something like that. It will function like OEM and look like it too. I've done it twice. This is far easier than most think it is. Connectors run about 20 bucks each, then some wire, loom and 1 connector to power it up. Works great.
Search for my post in a thread called something like "Warning, XE Foglights"
I really need to do a complete writeup on this, as nobody has ever done it OEM and show it. I'll get it done in a new thread next weekend. Bug me if you don't see it after next Saturday. I'll come back here and put in the link so others will find it easier.
