Is this the same thing as the MTX unit?
I think they may build it for MTX06titancrewse said:Is this the same thing as the MTX unit?
yes it gives you a left and right stereo output and a sub output as well.Blackbeauty said:So, what do you do? Plug this in between your HU and the speaker feeds?
Your installer was correct in a way about the rockford and Jl piece . Have not looked at the alpine. But they are njot like this. Totally different. It all depends on how serious you are about clean sound.BIGDADDY"S-07-CREW said:Rockford and alpine both make a unit like this. I was all set to pick one up and my local installer/dealer told me they are not worth it and to just do a LOC instead. FYI the rockford unit is like 4 bills.
I bet this guy has the loudest stereo on this site. Man I want to hear those mag2 12s. So bad.SirStrider said:tech,
So, with the non-RF system, you need amps?
I got this somewhere - supposedly the specs for the re-Q:
Additional Details --
Output Section:Number of Output Channels: Three (left, Right, Sub)Input Specifications:
Output Type: Unbalanced RCA’s
Maximum Output Voltage: 8V
Output Impedance: 432 Ohms
Signal to Noise Ratio: >90dB
THD+N: <0.1% at 1V out
Number of Input Channels: Three (Left, Right, Sub)Electrical Specifications:
Input Type: Differential Balanced
Input Range: 250mV – 30V
Operating Voltage: 8V – 16 V
Operating Current Draw: 150 mA
Standby Current Draw: < 4 mA
Recommended Fuse Value: 1A (Fast Blow)
Recommended Fuse Type: AGC
:cheers:
SPEAK UP - I"M HAVING TROUBLE HEARING YOU!!! :bang:tech12volt said:I bet this guy has the loudest stereo on this site. Man I want to hear those mag2 12s. So bad.
Nobody cares, TROLL!!!!!JAZZMAN40 said:I might be in!!
Not a troll!Blackbeauty said:Nobody cares, TROLL!!!!!
Blackbeauty said:Ok guys, just QUOTE this post and add your name to the list.
1. Blackbeauty
2. bbomar
I CAN NOT OFFER THESE AT THIS PRICE FOR LONG SO IF YOU WANT ONE ORDER ASAP. THANKStech12volt said:o.k. heres the link I have 10 people between the sites that claim they want it.
http://www.shop.tech12volts.com/category.sc?categoryId=31
