1 - 20 of 21 Posts
Stumbled across this:
www.trailmastersuspension.com
2004 – 2006 Nissan Titan 2WD/4WD Rear Traction Bars
* Trailmaster Traction Bars Reduce Spring Wind Up to Eliminate “Wheel-Hop” and “Shudder” Felt During Initial Take-Off of Vehicle.
* Traction Bars are Designed with Our Exclusive Urethane Encapsulated Flex Joint Allowing for Free Movement During all Spring Positions.
* Easy Installation with Detailed Instructions Included.
* Durable Silver Vein Powder Coating Finish to add a Great Look to Your Vehicle.
* Reduced “Wheel-Hop” Provides Traction by Maintaining Tire Contact With the Road Surface.
* Made From 1 ¾” X .120 Wall Tubing.
* This is a Complete Kit with All Mounting Hardware Included.
Qestion for you all: what kind of lift is shown on that truck? It almost looks like their own(Trailmaster) setup based on the logo on the front crossmember???
Amazingly light. 1/8" vs 1/4" thick steel. I would not consider it. I could twist that stuff with a pair of pliers. It's all about controlling a little bit of motion, that is not so assured, with 1/8" steel. Just not impressive, no matter the price.
Discussion Starter #6
07cajuntitan said:
Oh - wait...is that a pic from an ad?
Sure is!!!
Wow, that rear bracket ubolt plate does not look very strong AT ALL...
I could be wrong, but it might fit over the stock spring plate. like a large washer for all 4 holes...
Discussion Starter #9
That's what it looks like to me.
Banned
WTF did they get those bent at the local muffler shop? Nice kink bends, especially when you dont even need a bend in them. Those frame brackets are sketchy as hell too. Those might last a week.
PrerunnerGreg said:
You have to drop the fuel tank to mount those too.
Stop surfing the net and valve my shocks lol :poke:
I want the ones to make my truck look like it has a 4 link lol
Supporting Vendor (Gold)
Sammy Sandbag said:
Because to do so otherwise would cause the truck to burst into flames?
Actually, because the front mount is just a hole drilled in the frame. On the driver's side, you cannot get behind the tank to tighten the bolt. or the other bolts for the bracket.
They look like they mount under the axle instead of in front. That would kit 3"s of ground clearance.
1 - 20 of 21 Posts
