Radio said:I'm new at this, just want to know, do you have information on the frame thicknees vs the frame of the big 3, the frame is like a fondation on a house and very important before I by.
thanks. radio
Hello ricqik:ricqik said:Currently the tundra is the only 1/2ton that doesn't have a fully boxed frame. It is however fully boxed from the front to the end of the cab and behind that is a rolled C frame and is a one peice frame, unlike the many peice welded together like others. It had a stronger torsional rigidy than all other C frame 1/2ton at the time of it's release in early 99.
The titan's fully boxed frame measers about 2" wide, quite narrow, hmm.
Thank's Deepwater for that information, the Titan is my first choice for my new truck.Deepwater said:Nissan uses HIGH Strenth STEAL. For this reason they can make it lighter! It is every bit as strong or Stronger! It dose cost more to make the frames this way, the steal is very strong. It is also one of the reason why the trucks are lighter then the big 3. The big 3 have to bulk up the thickness of the steal in there frames because the Steal is not as Strong!![]()
