1 - 20 of 38 Posts
These seems to be frequently asked fuse locations.
The following diagrams shows different locations.
Older IPDM layout
Newer IPDM layout (black IPDM)
Location of IPDM and how to remove the IPDM to access lower row of fuses.
Fuse block (next to glove box)
Fuse and fusible link box (locate inside the IPDM box to the front)
Trailer running light:
Fuse #32 - 10A - IPDM
NOTE: The newer BLACK IPDM is label F4 on the IPDM itself but it's still #32 via the diagram.
Trailer left/right turn signal for 04-05 only
If you don't have turn signal to the trailer tow harness,
check by the BCM for two fuse holder (these get added if you have had the TSB done).
Picture of added fuses http://farm3.static.flickr.com/2471/3586159356_cefac98838.jpg?v=0
(Credit member SweetRide for the picture)
Trailer 12V accessory wire
Fusible link "j" - 30A - Fuse and fusible link
Fuse #51 - 10A - IPDM <<<This is to energize the relay only, it's the same fuse as reverse light.
Power port (aka cigarette lighter, cell phone charger)
Driver side #18 - fuse block
Passenger side #7 -fuse block
Center console #6 - fuse block
Bed #28 - fuse and fusible link box
Headlights
Low beam left #40 - 15A - IPDM
Low beam right #41 - 15A - IPDM
High beam left #35 - 10A - IPDM
High beam right #34 - 10A - IPDM
Stop lamp/brake light
Fuse #21 - 10A - Fuse block
This fuse also control the shifter lock, so if you can't get out of Park this fuse might be blown also.
Cargo light
Fuse #20 - 10A - Fuse block
Parking, license plate and tail lamp.
Fuse #37 - 10A - IPDM and/or
Fuse #53 - 20A - IPDM
Reverse/backup light
Fuse #38 - 10A - IPDM <<<Reverse for trailer harness
Dome light/door puddle light
Fuse #22 - 15A - Fuse block
Illumination-back light for radio and A/C knob and cluster gauge
Fuse #19 - 10A - Fuse block
Fuse #14 - 10A - Fuse block
Switch lights/back light on all your switch
Fuse #36 - 10A - IPDM
Radio
Fuse #31 - 20A - Fuse and fusible link box(constance power)
Fuse #4 - 10A - Fuse block (Acc power)
Rear view mirror (Inside - auto dimming)
Fuse #12 - 10A - Fuse block
Power windows
-Front windows
Fuse #4 - 10A - Fuse Block
-Rear windows - Crew Cab
Fuse #14 - 10A - Fuse Block
Horn
Fuse #25 - 15A - Fuse and fusible link
Adjustable power pedals
Fuse #15 - 10A - Fuse Block
well....I want the system off is what Im going for. Pulling the fuse out would be easier then pulling the bags out. I dont want to the blow up when Im out tin the dirt or if I nerf someone. So it would be safer for me to have the system off
Hello, new to this forum but not to forums in general. I did use the search function and came up short. I recently bought an 07 titan. It came with a key fob which doesn't work. I replaced the battery and tried the programing by putting keyy in and out till lights flash. they never flashed...so I'm wondering if it's the receiver. there are posts about this part as in it is part of the tpms and so on. My question is this, is there a fuse for it? And I would realy like to know exactly under the dash it is located. I've already read that it is near the pass side airbag, but I would like to look at it to see if there are wires unpluged or something else visualy wrong with it. Any help would be apreciated.
Don't forget the two bastard fuses under the drivers kick panel on the older titans. I believe that they were part of the bcm harness recall and were put in without any additional documentation being added to the manual.
Discussion Starter · #13 ·
I didn't forget them. It's posted in the OP.:D
☞ Sent from here☜
I bought my Titan in Dec 07 and after years of pulling boat and utility trailers I finally blew the #32 fuse. Thanks to the knowledgeable members of Titan Talk I solved my issue quickly. EXTRA thanks to 'Baseball" for taking the time to upload the diagrams. This forum is great! :redblob"
Reactions: AuburnTitan18
What about Trailer left/right turn signal for 06+? I'm current on all recalls as of this week, but STILL not getting power to left/right turn signal/stop plug (trailer harness is turn/stop combo) at the harness...
Discussion Starter · #19 ·
They changed for the 06+, it is now handle through relays. Do you have the required relays under the hood? You need two blue relay, one for left and one for right trailer turn.
Question for the wiring guru's, looking to wire up lights to come on when the truck is on/running and the headlight switch is off. Where would be the best place to tap?
1 - 20 of 38 Posts
