1 - 2 of 2 Posts
This may seam silly as I have replaced the pads on my 06 Titan several times. But today I didn’t pay attention. Here’s the question.
When you remove the slide pins, the one that receive the 14mm bolts which secure the caliper to its assembly, one is top the other is bottom, one has a small section of rubber on the end. The other is all steel.
Can anyone confirm whether the one with rubber on its top should be installed top or bottom of caliper.
Sent from my iPhone using Tapatalk Pro
1 - 2 of 2 Posts
