Can the bearings in the front diff be changed? I've heard that you have to swap the entire unit, as the bearings cannot be changed out by themselves.
It's an assembly. So you replace the entire unit.
That's what I thought, until I saw this: DIFFERENTIAL for 2007 Nissan Titan (item #6 on diagram). I was just curious if anyone has done it, or if I just need to shut up and color and save for an entire new front diff... Thanks for the input.
My apologies. I failed to read your original post properly. I thought I saw wheel bearing.
