About a week ago, I posted that I drained/refilled the transmission fluid on my 2017 Pro4x for the first time (at 50K miles) and that I would be performing the service on the transmission every 25K miles in the future due to the color of the fluid. I drained 5.4 quarts from the transmission. I also drained/refilled the rear differential. The fluid in the rear differential looked used, but not excessively so......I will continue servicing it in the future every 50K miles.
Now for the front differential. In the manual, it states the front differential (for non-xd version) should take 2-5/8 pints to fill. After letting it drain for 2 hours (when all dripping stopped), I measured approximately 1.9 pints. That's with the truck level on my concrete garage floor and my truck has no noticeable leaks. I then refilled the front differential, however it took 3.8 pints (??). Every differential I serviced in the past, you fill the differential until the fluid level rests just below the bottom of the fill port. Then, you check the fluid level every 10,000 miles, as Nissan recommends.
What do you make out of draining only 1.9 pints but refilling with 3.8 pints?
