I put a 2.5" spacer on the front of my truck and a 1" in the back. Shortly after I started to notice a loud clunk when going over several small bumps in succession. After trying different things and getting frustrated I disconnected the sway bar and zip tied it out of the way. The noise stopped. I wasn't a huge fan of handling without the sway bar. On stock springs and shocks its a bit mushy. I played with a couple other things and put the sway bar back. A week or so later, noise was back. And now my sway bar is gone again. It sounds like the front of my truck is going to fall apart. Is it the end links? They look pretty rough. Are stock replacements ok, or do I need to go with something else? What about the sway bar bushings? Should I replace those too?
