1 - 3 of 3 Posts
I have installed a rough country 3 inch lift on the front. ( strut spacers and uca's) while I was in there I rplaced the busted struts with bilstien 5100s and added the moog camber bolts. Now I get a creaking/ popping sound coming from what sounds like the drivers side. It's loud and sounds horrible but has been about impossible to replicate it. It happens at random. Sometimes a bump, or turning or just starting to drive. Everything is right and appears not to be contacting anything else. Any ideas or suggestions?
Did your replace your end links too? You can also go back and re-tighten the UCA's, when I originally did mine many years ago, drivers side wasn't tight and started clunking occasionally
1 - 3 of 3 Posts
