So I removed my grill today thanks to a few posts. I sprayed the chrome with black plastic dip. I could have done a better job applying the spray. But it looks good enough. And it's a product that can be removed easy. So about the grill removal and installation. There are 6 clips on top and 2 on each side for a total of 10.. that you rotate 90 degrees ..........there are also 6 clips. ( or tabs) that you have to pop out at the bottom of the grill. See photos of the truck and you will notice the slots. You will have to push the blade shaped part of the grill out of the slot on the truck... then it just comes out. To install just pull the clips from your truck. Install then into the grill, and push it back in. Pretty simple. The only curve ball was the Lower tabs/ clips. The second front the left was tough to reach. Also I found replacement clips online easy..... so no. You do not need to replace the grill just because a clip broke.
