I tried to put on my front hood deflector today. I did an inventory before I started. I realized that I did not have the center clip. I had an extra side clip though. Has anyone had this issue? Is the center clip really different?
Tony B
Tony B
Same here. They work fine all being the same.bg478 said:I installed the hood protector this weekend. It took 15 minutes from start to finish. I was also missing the center clip, from the installation instructions the side clips and center clip looked exactly the same. All holes in the protector lined up with all clips. I think the instructions were miss printed. BG
Does anyone know where I can buy some of the clear tape that comes with the deflector?Mike H. said:Same here. They work fine all being the same.
The small bite is normal. Very easy to remove, just take off the 5 screws and you can wax underneath if needed.homer said:I just picked up my hood protector today and plan on installing it this weekend. It looks pretty straightforward and I'm glad to read that the shorter clip will work for the center.
Two questions...it sounds like this can be easily removed, is this true? I plan on giving her the zaino treatment in the future and will want to remove it.
Also, there is a small bite taken out of it in the center, it looks like this is by design but could someone confirm for me that this is normal? I just want to be sure that it isn't damaged.
Many thanks in advance.
z3axv said:Does anyone know where I can buy some of the clear tape that comes with the deflector?
That's what I wanted to hear. Thanks again.spartan said:The small bit is normal. Very easy to remove, just take off the 5 screws and you can wax underneath if needed.
got_titan said:anyone have a good pic of the factory bug defflector installed. thanks
