to day I had my front struts replace with Monroe quick struts I thought it would raise the front end 2 inches but it raised it over 5 inches the shop said every thing is a max capacity that I might get a bottom out if I hit a large bump it does ride stiff now also I might get a little wear on the outside of tires, he set it as close as he could. I have faith in these guys as for alignment. I made have to remove the spacer 1 1/2 in thick I read on here that a 2 in spacer would work so I went smaller . question can I remove the spacer by just in doing the top nuts and loosen the bottom bolt or do I need to rotate the strut 180 deg.. to line up the bolts without the spacer , maybe the new struts did raise the height some also has any one had the problem thanks for any info.
