I've pulled a few. First you have to get three pushpins out of the top of the end cap. A small pocket screwdriver works good to pop the center out where you can pull them out. Sort of a tight area to work but be patient. There are two metal clips on the end you can take a pair of pliers and squeeze the sides of the clips together to get the clips out without breaking the plastic tab on the fascia cap. Then you have two more pushpins on the side closest to the inside, sort of like what holds the door panels on, see if you can push them out from the inside so you don't break the attachment points on the fascia. Then it should come right off.billgriffith said:
