First off I have an 05 4wd kc Titan SE. I have the factory cloth bucket seats up front and I know I need new covers for sure as mine are close to tearing on the driver side. In the backrest part of the front seats I can feel what appears to be the steel frame that has cut through the foam padding. This is with both sides of both front seats. The issue is on the backrest about half way between the top and bottom and only on the sides where there is thicker padding the fabric is a solid color opposed to the patterned part in the middle. The metal I can feel is running vertically if that matters.
I am sure there are probably tons of titans with this same issue as a friend of mine with an 06 has the same problem. My question is whT can be done to remedy this issue and keep it from happening again? I assume the foam pad will have to be replaced and I thought of putting some sort of smooth insulator on the frame that caused the problem. Maybe like a piece of small diameter PVC cut length ways. Any ideas or things I can do would be greately appreciated.
Thanks. Chris
Thanks. Chris
