Front Spring Compression How To
16K views 53 replies 25 participants last post by  theponi
PLEASE DO NOT USE THE ONES FROM HARBOR FREIGHT..!!! THEY ARE JUNK..!!! They are made with very cheap chinese metal and flex way too much. I've used them on a set of Honda Civic springs and they flexed horribly. Imagine using them on a set of Titan truck springs. I don't want to hear about you getting seriously hurt. Just go to Autozone and rent theirs, or if you are military go use the ones at the hobby shop. They have the nice table/wall mounted compressors.
I tried the Harbor Freight ones and one of them broke. They are junk. It's not worth getting hurt to save a few bucks.
Thanks for the detailed info Don but is it necessary to remove the spindle from the uca just to remove the strut assy? And why?
Do you need to compress the spring just to remove the shock/spring assy from the truck? If not, how would you get it back in under pressure?
