I have the possibility of picking up some used Icon Coilovers for cheap and was contemplating this until I read that I might need aftermarket UCA to avoid coil bucket contact. I emailed Icon to see if I would have any issues and they responded back saying as long as my lift is less than 6" there will not be any issues. I have searched this forum but have not run across the correct answer. Has anyone on here installed the Icon Coilovers on there truck with the Pro Comp Stage 1 with the OEM UCAs? If so are you still running that setup? Or is there no way around it and new UCAs will be needed? I have saved for new front suspension but if I need new UCAs with these coilovers, then it is out of my price range. Any input on actual application would be appreciated. Thanks
