1 - 2 of 2 Posts
does anyone know if the front swaybar on an armada is the same as the titan? or would it be a little beefier because of the added weight?
curious if it is bigger if it would make a viable cheap upgrade for stability?
The OE front sway bar are the same on both the armada and titan. I installed a Belltech front sway bar years ago; solid steel construction and made a huge improvement up front with handling and suspension.
1 - 2 of 2 Posts
