Are these on the stock Goodyear Wrangler SR-A tires? If so, it's probably just the tires-they are junk, I have only heard one good comment about them in the three years I've been on this forum.
Hmmm...makes no sense...they don't touch your tie rods just to swap out the disc rotors...I watched them do mine. Basically as easy and foolproof as an oil change. At what mileage did you have this done ?tg8826 said:I have an 04 titan that required the front brake assembly modification by nissan.
After installation, the tires immediately began to wear. Prior to this, I had no tracking or uneven wear indications.
Has anyone heard/noticed if the out to out wheel width may have been widened ever so slightly so the wheel bottom toes out and causes excessive wear?
