1 - 3 of 3 Posts
Hey crew with the sudden weather change up here my windows fogged up pretty good and for the life of me I cant get any flow of air onto the windows. The feet yes but on the wind shied not much, and yes it was on the right control. I remember this from my last titan but not this bad. How do you guys get better air flow to your front wind shield. The fan is blowing like a bugger but not where I need it, TIA
Sounds like either a stuck flapper door or a bad actuator. I've heard the linkage can bind and screw up the door movement. I need to crawl under my dash and check mine, for the opposite problem. When I put the heat on floor, I get too much flow from the defrost, and it gets hot on your face before your feet warm up.
Reactions: schmidtmike76
1 - 3 of 3 Posts
