1 - 20 of 21 Posts
I removed my audio system prior to selling my '04 Titan. I've moved on to other projects, and would like to clear my garage of all these old items. I say old, but these parts are in outstanding shape. I didn't have them installed for long and too exceptional care of everything when installing and removing. Everything is in "like new" condition and has been tested to work.
If you'd like to see all the components I used and how I did the install, just check the thread here: http://www.titantalk.com/forums/tit...-matrix-comps-subs-pacswix-optima-sirius.html
If there's something not listed for sale, but you want to buy it, let me know. I have boxes of stuff I still haven't gone through.
All prices are shipped to lower 48 (unless otherwise noted.) If for some reason shipping turns out to be way out of line, then I reserve the right to cancel sale (and refund your money) / ask for additional funds.
1. SOLD! Titan 3/4" MDF speaker mounts. These are for mounting 6.5" woofers in a Titan CC (may work with KC back doors.) You'll need some small bolts and nuts to mount to the door (stock screws not long enough to go through 3/4" MDF.) Painted black, foam tape on backside. Metal speaker rings not included unless you also buy my Kappa speakers (see below.) $35 for all four shipped
2. SOLD! Infinity Silk Dome Tweeters. Included are the inline crossovers. Already mounted on a pair of Titan forward tweeter grills (included.) $15 shipped
3. SOLD! (x2) Infinity Reference 7520a # 97 watts RMS x 2 at 4 ohms, 142 watts RMS x 2 at 2 ohms, 283 watts RMS x 1 at 4 ohms bridged. Read more about it here here
Great amps, either driving components or bridged for a sub. A similar amp would cost well over $150. $75 each shipped or both for $125 shipped.
4. SOLD! Infinity Reference 1210a Class D Mono Sub Amp. 854 watts RMS x 1 at 4 ohms or 1300 watts RMS x 1 at 2 ohms. Great amp for a couple of 10's or 12's that can handle some power. I drove two Soundsplinter 10's with it, which was way more than enough. Read more about it here. Still have the original box. Reduced!!!! $180 shipped.
4a. SOLD! Infinity Reference RC100 bass controller. Designed to work with 5760a, 310a, 610a, and 1210a amplifiers. Cable not included. $10 shipped, or if you buy my 1210a I'll throw it in for free.
5. SOLD! (x2) Infinity Kappa 60.5cs Component Speakers (6.5".) Power range 2-90 watts RMS. Great sounding speakers with a solid construction. Designed for 4 ohm signal. Work great paired with the Ref 7520a I have for sale. Read more about them here. I'll also include the tweeter rings for the rear doors of the Titan, in addition to all the other Infinity mounts (if buying just one, specify if you want it for the front of back door.) $75 per pair shipped or $125 for all four shipped.
6. SOLD! JL Audio 8w0-4 8" Subwoofer. Power Handling 150 watts peak RMS: 75 watts RMS (4 ohm.) Great little sub, looks brand new. Works well in small sealed enclosures and has only a 4.063" mounting depth. $45 shipped.
7. SOLD! Knukonceptz ground distribution block. Two 0ga and four 4ga terminals. Solid piece in almost new condition. $8 shipped.
8. SOLD! Scosche radio install kit. I added the little MDF & foam pads so that the radio was better supported. $25 shipped.
9. Custom radio bezel. I fiberglassed this out of a OEM 2DIN bezel. Fit perfectly around my JVC stereo, may require some work to fit yours. The small hole is for a PAC-SWIX IR LED. $15 shipped.
10. SOLD! Titan fuse box cover, graphite. $5 shipped.
11. SOLD! AudioControl Matrix 6-channel line driver. Quality product made for boosting your stereo's pre-amp output voltages. Helps improve the sound by not forcing you to drive your amplifier gains way up. Read more about it here. They are still in production and go for $200 new. This one might as well be new, no signs of use. $110 shipped.
12. SOLD! Fuse block and fuses. The fuse block is two 0ga in, three 4ga out. Uses ANL type fuses. I also have 2x 60A, 1x 200A, 3x 80A fuses available. Buy the block and all fuses for $30 shipped. Block alone for $8 shipped. Fuses $5 each shipped.
Paypal is preferred payment, but I am will to work with you. All items will be packed with the utmost care and shipped within one day of payment. Shipping will be at the least expensive means, so tracking is not guaranteed.
I want a pair of the Kappa components! still for sale?!?1
Damn! I figured I was too late
I'm wanting a good amp for running to subs, an amp to run good component set. And I really like that single din radio bezel but I'm scared it won't work with my deck. Pm me about these items please bud.
Damnit, I wanted the Kappas.
I would love to buy them, but I'm broke. lol...
1 - 20 of 21 Posts
