1 - 3 of 3 Posts
TAP Auto Parts is now an authorized dealer of the entire line of MaxTrac Suspension for the Nissan Titan.
Maxtrac Suspension's 2WD lift spindles are a simple, but extremely effective way of gaining additional clearance in the front of your vehicle. By simply replacing your stock spindle, you can achieve an additional 4", while maintain a factory ride by using stock control arms, springs, and shocks. Maxtrac's spindles are made from Ductile Iron, and are designed to be 100% bolt on, with no modifications necessary.
SPECIFICATIONS
  • Ductile Iron Construction
  • 100% Bolt On Installation
  • Maintains stock ride quality
  • Increased Ground Clearance
  • 4.75" Max Backspacing
  • Kit includes front extended Stainless Steel Brake Lines
Installation Instructions for MaxTrac 4" Spindles / Nissan Titan-Armada
MaxTrac Rear Shackles for the Nissan Titan
04-13 NISSAN TITAN 2″ REAR LOWERING SHACKLES - 415320
04-13 NISSAN TITAN 1″ REAR LIFT SHACKLES - 715310
  • Maintains factory ride quality
  • Levels the rear with the front of the truck
  • Urethane Bushings for less binding
  • Zerk Fittings
MaxTrac 2004 - Current Nissan Titan & Nissan Armada 2.5" Leveling Spacers
Maxtrac Suspension provides extremely high quality fabricated strut spacers made from 1/4" steel, stamped top plates, and standardized hardware across all applications. Maxtrac knows that the leveling market is highly competitive, and that is why our parts are some of the best in the industry in quality and pricing.
  • 1/4" Fabricated Steel Construction
  • no strut disassembly required
  • Maintains Factory Ride Quality
  • MAX TIRE SIZE: 33"
Need shocks? TAP Auto Parts has you covered. Add a set of performance shocks to any of the MaxTrac lifts above for the ultimate in ride comfort and offroad performance.
Bilstein 5100 Adjustable Shocks
RadFlo Suspension
ICON Vehicle Dynamics Coilovers
King Racing Shocks
TAP Auto Parts KNOWS trucks! If you have any questions please contact us.
Want to Order?? Visit Tap Auto Parts for the 4" Lift Spindle
Every part listed above is USA made!
Don't forget we also carry a full line of offroad suspension, lowered truck suspension, offroad lighting and performance accessories.
Total Auto Performance - Las Vegas, NV
702-979-1577 | 888-244-6166
1 - 3 of 3 Posts
