They will clear the coil bucket on my Xterra so I assume they would on a Titan. They are of function the same as the Metal Worx/Total Chaos/Camburg, providing more articulation and clearance of the coil bucket but due use of a standard ball joint I would bet they do not have the same amount of drop/compression range as the others. Which mostly likely is negligible in all reality of real world performance considering that your coil-over will most likely max out before the limit of the ball joint is reached.Will these still hit the bucket if untrimmed? Concerning clearance, how would these compare to a Metal Worx/Total Chaos/Camburg?
Sent from my XT1575 using Tapatalk
