FS: SAW 2.5" Coilovers
1976 Views 19 Replies 8 Participants Last post by  djalex
I will be selling my SAW 2.5" coil overs for $700. I believe you will need an upper arm like Total Chaos to run this. This was the setup I purchased from Greg. I am getting the mid-travel kit and have a new set of SAWs on order.
DJAlex
1 - 20 of 20 Posts
These coilovers have only been installed for about 4 months and are rebuildable.
Hey, I pm'ed you. I will also take the TC arms if this setup will work with my
6" PC lift. Thanks, Jon
These coilovers will not work with a bracket lift, they are too short.
but they will b/c he has the top spacer....he just won't be able to see the kewl red through the wheel wells
why not get shocks made for a lifted app instead of stock height shocks and still use the spacers? LOL sorry, just a thought...
These 2.5" SAW will work with Greg's new mid-travel kit. I also have a set of Total Chaos arms I am selling. I will soon post pix of the mid-travel kit installed on my truck.
jason27 said:
would they work with the pro-comp lift??
That's what the majority of this thread has been talking about!!!!:readclose Haven't you read any of the replies??? Not being a d1ck, just stating the obvious.
Correct, the ProComp lift IS a bracket lift, but the shocks will still work, just have to re-use the spacer.
Correct, but you don't gain any extra travel over the stock shock either. Why not eliminate the spacer if you can???
Yes, that would make the most sense.
SORRY, totally skipped over the post that NYmxer left....
I am selling both the SAW coilovers and TC upper arms for $1000. According to Greg these will not work with Procomp, Fabtech, or CST 8" lift. There is a different SAW available for those lifts, which is longer. I don't believe you can use a spacer with the SAW. The pictures show the PRG mid-travel kit installed with these coil-overs.
How much for the arms by themselves?
TC Upper arms $400
Judging by the fancy bumpstops, I'm guessing these SAWs have seen some heavy action.
These are the PRG valved SAWs correct?
the beauty of aftermarket coilovers is they can take the abuse unlike a stock shock which subjected to the same amount of abuse would likely be blown. with the huge air bumpstop djalex has, if you knew its purpose, you'd know that the bumpstops actually help lessen the abuse the coilover would be subjected to if in fact he did see heavy action.
I imagine the air bumps have valves that bleed air back out, very slowly and under alot of pressure possibly so it acts as a shock in itself sortof... how much does stuff like that cost?
I understand all of that........elementary.
What my point was that these used SAWs have seen real action........not from a poser vehicle.
Yes these are the PRG valved SAWs. I have gone offroading with them and they still handle great.
7
poser vehicle... LOL!!! nope, DJalex was out there with us running the MDR race course out in Johnson Valley not too long ago! he definitely saw action! the PRG spec'd SAWs are the sh!t...
I just dropped off my truck at Allied Motorsports this morning. They will be installing a shock hoop and longer SAWs. So these SAWs will be ready tomorrow for those still interested.
1 - 20 of 20 Posts
