I have a US Amp Md1d mono amp for sale. It is currently pushing two RE SE tens at 1 ohm in a sealed box. I am looking to get $155.00 shipped for this amp. If you are interested I can be reached at [email protected] or you can PM me. I will be posting pictures up tonight or tomorrow.
Here are the specs of this amp......
* 1200 Watts RMS @ 1 Ohm
* 750 WATTS rms @ 2 ohms
* Bridgeable with multiple MD-1D amps
* Efficiency:
86 % @ 4 ohms
84% @ 2 ohm
76% @1 ohm
* Built-In Electronic Crossover, Selectable 24dB per octave butterworth (adjustable 40-250 hz)
* 24dB Subsonic Filter 15-40 HZ
* Bass EQ 30 dB @ 45 HZ (This bass EQ on this amp has a much bigger punch than any other amp we have ever carried)
* Low level RCA input
* Block power connector
* requires 4 gauge power and ground wires
* 8 - 18 gauge speaker wire inputs
* Aluminum heatsink
* Screw terminal speaker connectors
* Convention cooling system
* Digital Class D efficient power supply
* Frequency Response: 20 Hz - 250 Hz
* 3 x 30A fuses!
* Efficiency:
86 % @ 4 ohms
84% @ 2 ohm
76% @1 ohm
* Aluminum heatsink
* 3 x 30A fuses!
