I noticed that my gauge said 0 miles to empty but the needle was still above the "E" line, i filled it up completely earlier to see how many gallons I could pump in the tank to my surprise i pumped only 22.7 gallons, so there is definitely something going on in the gas tank or the ecm, i went for a drive down the freeway for about 15 miles (the onboard computer read "range" 352 miles to empty)i know it sounds like quite a bit but it never changed in those 15 miles that i drove, it stayed at 352. I wonder if i disconnect the negative battery cable so it can relearn to oem specs. Any ideas, (i hate to drop it off at the dealer for a day , and yes this is on an 08 Titan Pro4x BT CC .
