1 - 8 of 8 Posts
I can't find the fuse block diagram (with labels) in the owners manual or the service manual. I must be going out of my mind. They can't not have what the fuses are.
I am trying to wire my XM into the ACC power supply, or something comparable that is off when the ignition is off. I had the old XM plugged into fuse 6 and fuse 22 on the passenger side foot well fuse block.
ACC to the stereo is the violet wire, can't help you with the fuses off the top of my head though.
I used the wires to the power point's on the dash. The right one is switched, the left is constant. Both are green, the grounds are black. I used those yesterday for my dvd install. use t-tap splices if you can, much easier.
No you're not going crazy, albeit a long time ago, I am searching also to no avail. Does anyone have this info?
on the cover of all the fuse box covers it shows what fuses are what. there isnothing in the manual but when u take the cover off look at the inside of the cover is says what each fuse is for. i dont know if thats what ur looking for. i might b understanding wrong but from what i get thats whatu want. is to know what each fuse is wired into. sorry if im totally off lol
Yeah, I got it all. Blackbeauty helped tremendously. I also paid for a complete wiring diagram, 86 page PDF, which I will peruse and know more about ASAP.
Testing Signature
1 - 8 of 8 Posts
