Do the mini blade fuses work as replacements for the original fuses? they seem alot bigger? Took a fuse to Auto-Bone and they didnt have it. They had never seen a fuse like that before. Neither have I. I looked on here for a thread but there is so many..but none that i saw about this problem. Im sure this has been adressed many times..sorry for the repeat.
thanks man. Glad to see that there are replacements available,other than at the dealership. I will be buying a few just in case I pop a fuse again. Auto-Bone had never seen them before..Hell could have told them it was from a spaceship and they probably would have beleived it.
The fuse difference is even mentioned in the onwers manual and they also mention that if you use the standard minis inside that they will stick out some - but will work fine.
I got a few replacement fuses to keep on hand and almost got these ones that light up when blown. My camper has them and it's real handy to when you blow something.
TitanBlue said:
Thanks titanss, you come to the rescue again! :thumbsup:
Now, both sites can find the info a lot easier...:bouncy:
No Problem TB. Now if the owners will mod the four letter word blocker (what ever it is called) so we can link over to CT with out a How To explanation to see the link, they just bought CT a few days ago, it would be a lot easier to link between forums.
