1 - 18 of 18 Posts
What is the deal on the fuel mileage on these things? My F-150s were not great, but this is ridiculouts. I'm getting 8-13 mpg. Horrible.
I'm getting surprisingly good mileage on my 2010 CC 4x4 SE, 15-16 mixed driving and I keep that go pedal to the floor quite a bit.
are you figuring it yourself or goin by the info box on your speedo?.. i just put an intake and swapped the muffler out for a maggy on my 2010 and my mpg has gone down? i mostly keep my rpms below 2k... cant figure out what the deal is... i went from almost 15mpg to 13mpg
I must admit my 05 Titan was alot better , but this new 10 is ridiculous. In town I am averaging 9.8 to 13 mpg's. The dealer said it should get better after 7k miles. So if I hold my breath and with some wishfull thinking.... I might jump up to 14mpg's??
I noticed the decrease more so after installing a CB exhaust.:confused:
I'm seeing 13.5-14 around town in my 2008 CC 4x2 w/ the 2.94 reaer. On the highway I get 19-20 at 72-73ish. It's about 1 mpg worse than my father's 2006 F-150 4x4 in town and a smidge better highway.
I was a bit frustrated with the MPG too. I read 14 city/18 highway before buying the Titan, but in reality, I'm seeing 11-12 in stop & go traffic. I'm not a fast driver by any means, but I was hoping for closer to 14 at least :(
I think I got 16 MPG on a highway trip, but the tires weren't inflated right (from the dealership).
Lifted with BT and 35's I get about 10-11 city and 13-14 highway.
The ford had an engine that belonged in a Honda Accord. The Titan has a fire breathing monster under the hood. It needs to be fed.
2011 pro4x- Im getting 14 in town with easy driving...not sure about the highway though only had the truck a month.
I used to get 13 with mixed driving....newer f150 was pulling about 14.8 : ( but it is a ford
Any truck with 4wd & 4.10 gearing gets the same mpg. GM & ford use 3.73 gearing as their standard with 4.10's as an option.
I had an '05 and averaged ~17 mixed. When I got my '09, my mileage was around 15 mixed. After ~5K miles, it improved a good bit and today I'm averaging ~17 again.
Give it time and gas - she'll be fine.
my 05 lifted with 35's and bt only gets about 10-11 mpg on the highway and 8-10 mpg around town but i only got a couple more mpg's before the lift and tires..... but i wouldnt change a thing i love these trucks
Discussion Starter #18
Mine is the XE and doesn't have the mileage display in the speedo, so it is my calculation. My F-150 did have the display and it was fairly accurate when compared to manual calculations (the average anyway).
1 - 18 of 18 Posts
