Hey I have a 2004 XE 4X4 Crew and it dies when driving down the road or at idle, some times it will re start right away, some times I gotta sit for a while.
It has a brand new not re furbished, IPDM and ECU and all new relays and fuses.
other parts replaced are new spark plugs new fuel pump, and new crank sensor.
it has JBA long tube headers and Cajun B pipes, uprev tune and a no name intake.
it is going back in in Monday and gonna have compression and leak down tests done.
there is no check engine light and the only saved code is a multiple mis fires.
The mechanic and I are both completely stumped and have no clue where to go from here.
idle is set at about 600 is that too low? Could it be a bad coil pack?
or tuned too rich at low throttle position and at idle?
