Are you going to do before and after Dyno runs?
I wanna see video of when you hit it
hahahaha me too!:big_grin:Are you going to do before and after Dyno runs?
I wanna see video of when you hit it!!!
I 2nd NX Kits and make sure you are running a "WET" kit for some great results. My old Cam only 94 Formula would run 12.8 in the 1/4 N/A and [email protected] on the NX 150 Wet Kit all day with 1K PSI.Nitrous express!
I like two stages if running a shot that big or a controller. That way you can do 100-125 out of the hole and bring in the rest as traction permits.I will go with the responses. NX kit. I am going to go with a 200 shot setup .
Hello, I absolutely am going to set a 2 stage. Since I only need 2 buttons to change Maps with uprev I will use the last one on a relay setup to stage 1 and 1+2, resets relays to stage 1 when you are fully off throttle. Easy mod IMO.I like two stages if running a shot that big or a controller. That way you can do 100-125 out of the hole and bring in the rest as traction permits.
Have fun and make sure to post up videos when finished.
Dustin
When I ran a 50 shot you could barley feel it on a V8 application. 100+ is where you really feel it and say I like that.As an amateur, I am interested in a small nitrous shot. thinking about a "ghetto fog," for lack of a better word(s). I would like to go with a 20-50 size shot, just enough for nice pick up when passing a semi or two.
what do y'all think?
ok. good to know! thanks!When I ran a 50 shot you could barley feel it on a V8 application. 100+ is where you really feel it and say I like that.It would be a waste of $$$ just for passing power to add a kit.
