1 - 15 of 15 Posts
Making the change, I assume it is a simple swap but wanted to double check. I looked at CourtesyParts and it looked like there were some extra bolts with the BT kit, don't know what those are for. Any input would be nice.
i am waiting on a set to do the change too. would like to know any input submitted as well.
It's a perfect swap for all years/models. Bolt the old ones off, new ones on.
The mirror assemblies are identical, minus the actual mirrors obviously.
I got mine brand new from Scott at Fontana. Give him a call.
Yeah, LOOK OUT for the extra width, says my garage door.
the BT mirrors comes with all the hardware that you need, back plate and bolts
just make sure you get the BT mirrors for the SE not LE since the LE has a different connector if I assume you have a SE
Reactions: thad5515
The only difference I know of is whether not you have memory seats, so you'll need to order the mirrors accordingly for the wiring harness to match.
i swapped a guy with BT from his LE model to my non big tow pro4x and the plugs were different so i have manuel mirrors now it sucks
Ya, I gotta fold mine in everytime I pull into the garage.
Fortunately I have about 2 inches on each side, so I can squeeze in.
Does anyone know of a place that sells a replacement for the bottom curved mirror on the BT mirrors?
Cool pic of the T doin it.
I'm sure your local glass shop should be able to fit it.
Trust me, as I was typing I had the same comment to myself. :ftard: LOL
I was fighting the urge to post my comment.. but with all the other stuff that goes on there I had to reply to it. Either way you can't let those opportunities slide.
1 - 15 of 15 Posts
