1 - 10 of 10 Posts
My name is Nelson and I own a 2009 Titan 2wd (Poseidon). She's sitting on a 6.5 inch maxtrac spindle lift currently. I would like to fit 37s-38s without throwing away my old lift and buying a new bulletproof $4000 10-12 inch lift. Is this possible, thank you!
Maybe a 3" body lift. You may need to trim some, but I don't know. There were a set of 37" tires in the buy sell section. I would look for it and pm the guy and ask him what he needed to clear them. Most guys on here are pretty cool and will help if they can.
whats your wheel offset and width. thats a huge factor.
Thanks for quick response. I'll have to check out the 37's in that section. Know any good company's for a 3" body lift. Is it a hard install?
Right now I'm running 35x12.5x20. My rims are fuel hostage 10x20. They are not the super deeps dish rims but the mid way looking ones if that makes sense. I had to trim about one inch off the driver and passenger wheel well. My offset was I believe -22 or something like that. I don't remember exactly but my tires stick out about 2-3 inches from the side of my truck.
A body lift will help but if you dont put one on You'll need to trim. More than just plastic. I'm running 37x13.5s on a 20x12 wheel with 2" spacer.
Sent from my SM-G928V using Tapatalk
we're running the same wheels and the offset on the Hostage is -24mm. lots of trimming will be needed if you wanna stuff 37's in there!
I too have the maxtrac 6.5 inch lift on my titan and am wanting to go with moto metal 961's 18x9 18mm offsets and am wanting 35's on it. Do you think I should be okay with a 2"wheel spacer? I want little to no rubbing at all
i'm sure you'll rub
Most will do the PWM mod. Here I had to cut the bottom of the fender since even after the PWM mod I still rubbed.
1 - 10 of 10 Posts
