Nice! So I'd probably get about 39" to 39.5" up front with them set at "0". I think I might need to get me a set! BTW, how is the ride compared to your 5100's on the top setting with your stock springs?
It's not that noticable of a difference. The 4x2 springs I received with the Bilsteins were pretty worn down so it offset the preload created by the Bilsteins on the top setting. That setup was not stiff at all.Nice! So I'd probably get about 39" to 39.5" up front with them set at "0". I think I might need to get me a set! BTW, how is the ride compared to your 5100's on the top setting with your stock springs?
I actually have it on the middle setting, and I love it. It's not stiff at all.So how is the ride with the highest setting? I really need to get my 5100s back on the truck.
Good job taking the sway bar off, it helps a ton for ride quality. Just wondering, are you leveled now front to back? I know Nissan changed rear leafs on the 08's, but I don't know if the 08 2wd rear end sits higher?It's not that noticable of a difference. The 4x2 springs I received with the Bilsteins were pretty worn down so it offset the preload created by the Bilsteins on the top setting. That setup was not stiff at all.
I test drove this setup for about 10 miles after I finished the install (and removed the sway bar after the install), and I liked it a lot. I think allowing the truck to work independently with the stiffer springs without the sway bar interfering helped.
You need adjustable cam bolts and an alignment.I just put the 08+ springs on my 4x2 kc with Bilstein HD's and its got quite a bit of positive camber..
Thanks, I'd read I didn't in a prior post regarding small PRG lift... are the cam bolts only avail aftermarket? I don't want to mess up new tires waiting for proper partsYou need adjustable cam bolts and an alignment.
I'm guessing the OP does too ... madrock should be getting about 3" with that setup not 5". The middle setting gives 1.5" so that would be 3.5" from the coils. Sounds like the tires are on their edges.Good job taking the sway bar off, it helps a ton for ride quality. Just wondering, are you leveled now front to back? I know Nissan changed rear leafs on the 08's, but I don't know if the 08 2wd rear end sits higher?
For some reason 2wd guys have been getting some crazy lift numbers from this set upI'm guessing the OP does too ... madrock should be getting about 3" with that setup not 5". The middle setting gives 1.5" so that would be 3.5" from the coils. Sounds like the tires are on their edges.
Not 3.5". Even if they are Pro4x coils maybe 2". Since the truck's an '08, it didn't come with cam bolts, so the camber being off would explain it, and even Toe can cause this.For some reason 2wd guys have been getting some crazy lift numbers from this set up![]()
pictures!!!
My stock 08 sat exactly like my stock 06, which was 35" up front and 37.5" in the rear. I picked up some 1.5" blocks and Bilstein 5125 rear shocks from Mr Lee, but I kinda digging the stance as it is now.Good job taking the sway bar off, it helps a ton for ride quality. Just wondering, are you leveled now front to back? I know Nissan changed rear leafs on the 08's, but I don't know if the 08 2wd rear end sits higher?
I posted a frontal pic on the original post. I have some positive camber, but it is nowhere near as bad as I thought it would be. I just installed the setup last night so I haven't had it aligned yet. I get my tax refund on June 3, so I'll get new shoes and the alignment done all at once.Not 3.5". Even if they are Pro4x coils maybe 2". Since the truck's an '08, it didn't come with cam bolts, so the camber being off would explain it, and even Toe can cause this.
madrock, did you get it aligned? Did you buy cam bolts?
My guess is that the 2WD are a lot lighter and don't compress the stiff 4x4 springs as much.So bilsteins on the middle is 1.5"s of lift... and 4x4 springs are another 1" of lift?... which = 2.5"s of lift, how did you end up gaining 4-5 at the fender?
Truck looks great tho! Good work!
