1 - 2 of 2 Posts
What is a good performance oriented street tire that fits the stock 18" wheels? This is a truck that would virtually no use off the paved road.
Thanks!
you can use a 285/60-18. it a bit wider, and a hair shorter (when you speedo says your going 60, your actualy doing about 58. so its not off my much) then stock but i know of quite a few guys going with this size cause they have tons of options out there for street tires.
also i had thoughts with going with with a toyo proxes in a 305/60-18. they can be fit onto a stock wheel just fine. and they are exactally the same size. i decided against it when i got my 24's cause i need a good tread that will run in snow for the winters around here. im planning on revos in stock size when my stocks wear out. check them out. good luck.
1 - 2 of 2 Posts
