I'm having a sub box built but am unsure as to which color carpet I should order to match my steel interior. Should I get light or dark grey?
Thanks - great forum by the way. helps a ton with my new truck!
You having Tech build you one? (I hope so, you'll be unhappy if it's not one of JT's boxes!!!)
The color you should probably get is the dark gray. I got the light gray with the steel interior and it's not quite right...it's a bit too light.
Psychlone
Psychlone
After reading through these forums, I sure am going through him! Thanks for the heads up.
the steel matched the darker grey better than light grey i carpet boxes every day and mine is steel as well.. go with the darker even if its a hiar off it will look better than being to light
