1 - 20 of 30 Posts
Well here is a sub enclosure for you guys that do not want to take up much space and it downfiring. Has plenty of room for the sub to move . it can be placed on eiother side of the hump. It will be carperted to match your carpet. This one is for a customer with dark carpet and the pics are in my truck which has light grey. The sub is boston g1 10 and man it sounds nice. this is a great addition to the factory rf or any of the factory Titans.
price 199 plus shipping with the sub.
I almost forgot i even tried this sub with the factory amp at 2 ohms and it was an improvement . Big time.
Can you make one for an 8" sub. How much empty?
Nice James,
That box sure does look familiar... :)
On a side note, If you want it upfire all you have to do is flip it over and spin it around.
Very nice! What is the volume and max depth?
Tech,
Just a quick couple of ?'s Will this fit a King Cab, Do you need an amp, how hard is installation, and could you guide me through the installation part?
LATitan1 said:
Tech,
yes it will fit a king cab . its actually what its built for. you can use the factory rockford amp. but it would sound better with a small amp like the gt 20. i send every customer my number incase you get in trouble.
http://shop.tech12volts.com/product.sc?categoryId=18&productId=77
now that you have a titan, any chance on the under the front seat version?
Discussion Starter · #11 ·
yes i have actually played with it a little. there are two problems. the seat seams to rattle like crazy with a sub under it. I assumed it was the plastic enclosure untill i built a wood enclosure and added my ads 6 inch sub. the factory enclosure does rattle but alot of it is the seat itself.
Im still working on it.
Perhaps you could build a reflex enclosure and have it port out the front or back of the seat... instead of up under it! :) Or just put a grill on it like the PRO-BOX!!! :jester:
Grill = +2 db
+5 db if you rhino it!
thanks tech12v,fyi I've got the kenwood under the front seat and it also rattles the seat.
bigjimbo said:
what about ionizing it??? That way it wont rust!
No No No
Powder Coat them for +10db
Isn't chrome good for +12db?
1 - 20 of 30 Posts
