Gutted my primary cats today
With 115k miles and code P0420 ever present, I decided it was time to gut the front cats.
I unbolted the exhaust from each cat, and slid the pipes back. I used a 2x4 to wedge the pipes up out of the way.
A long screwdriver and a hammer was used to break up the material in the cats. A firm tap on the side of the cats worked well to spit the material out. When nothing else would come out, I used a vacuum to suck out any hidden debris. Last, I cranked the truck up and let it run for a minute, to blow out anything I might have missed. Sucker was loud! :lol: Bolted the exhaust back up and hit the road. Took about an hour for each side.
Before I hit the road, I cleared the code out using my BDGT and monitored my AFR. Before, I was running 12.8 at WOT. I'm running a little leaner at 13.3, but hopefully it will re-adjust over time. So far, the code has not come back.
The exhaust is slightly louder at WOT. Otherwise, I can't tell a difference in the exhaust noise level (My exhaust is stock, except for the gutted cats).
As far as power, it pulled good. I'll have to make some 0-60 runs to see if there is an actual improvement.
I'll update this thread later with any change in mileage, and if the code comes back.
Here's a few pics.
This is your Titan's Cat
This is your Titan's Cat after surfing TitanTalk
Someone call Al Gore. :teethmast
Here's a few pics.
