Are you happy with your purchase, ride quality? Any regrets? I'm thinking about this kit along with 5100's.
Nissan Titan Leveling Suspension
???As of right now...I am happy. Just beware the instructions...as they can be misleading or flat out wrong in some instances. Also, if you are running 17inch rims, you will need to upgrade to at least 18 inch rims as the components are too big. Other than that it rides decent. With the Bilsteins, I think my ride is better than it was before. I like the way it sits.
It's just the level kit, what you say is correct for the 6" and higher lifts.As of right now...I am happy. Just beware the instructions...as they can be misleading or flat out wrong in some instances. Also, if you are running 17inch rims, you will need to upgrade to at least 18 inch rims as the components are too big. Other than that it rides decent. With the Bilsteins, I think my ride is better than it was before. I like the way it sits.
Much appreciated.Had one on my 1998 Dodge ram for 7 years with no problems at all. Just make sure you get a front end alignment after you install it.
I've read a few times about the lack of instructions. Seems like fairly simple task. Thanks for the info.Just installed mine about two weeks ago. i love it, looks and feels like a truck should now. I have stock rancho struts and 17" stock rims and everything fits fine. Only thing is i got a body lift coming and 35/12.50 tires goin on so i had to order wheel adapters to make the tires clear the UCA. Instructions were okay at best, it didnt specify on some things but if you have any kinda mechanical back ground you can do it no problem.
Good luck
-dave
Please do. I'd like to hear your opinion on it. As far as the tires go, they said that this level kit was built around a 33' tire platform. Once my 31's wear down, I'm going to order a bigger tire.I just put one on and will let you know in a few days. I am yet to drive it, have an alignment appt tomorrow. I am also considering Bilstiens. What tires do you think you can fit under it? I'm considering 295/70/18 Terra's on xD Monsters.
Thank you, sir.???
I am running the RC level kit with my stock 17's no problem.
:read: HahaMy bad...I read Rough Country lift kit...not level kit.
