heres a link on adjusting the beam pattern but to adjust the headlight you need to access the two screw that are on the headlight itself one is for horizontal and the other is for vertical adjustment. you will need do go in through the wheel well dont think you can reach through the top, no room, but i could be wrong on this one.
http://www.coolbulbs.com/HID-VISUAL-HEADLIGHT-AIMING-PROCEDURE.pdf
