So my back up sensors are currently working, but they are intermittent and sometimes I get an error on my 2010 Titan.
I have done a lot of research and noticed that people have had many different problems.
I did the test and I believe the outer sensor left is bad, Since I get a 1-1 error code.
I also think that its a sensor because last year in the winter and after a car wash it put the system into error mode. After it dried out it was fine. This was the start of my ptoblem and happened a couple of times.
I also inspected all of the connector plugs, and cleaned them with electric cleaner, although they were all already clean.
I have noticed the OEM sensors are about $200. There is also a cheap $20 generic version of the sensor. I always go with OEM, but taking a gamble on the $20 sensor seems like it may be worth a shot.
So in conclusion, Has anyone used the cheaper $20 ebay sensors and how did they work or last ? And any other advise to my problem is welcomed...
Thank you
Dan
Thanks Nick name. Some good information and that link has several brands.
Before your response to ordered a set of 4 sensors from ebay for $29.00 in the US. They are said to be kansmart brand. Anyways I was just going to replace all four, but I just replaced the 1-1 Outter left (based on my error code) and it fixed my problem.
So the senor worked and I have a few extra on the shelf.
Just an update incase anyone needs the info in the future. If it fails ill try to update the post.
Thank you
Dan
