ratcheting wrenches are the best. they save my *** at work all the time
Have to agree with this lol. I have a huge assortment for work, my day would be twice as long if I didn't have themratcheting wrenches are the best. they save my *** at work all the time
Glad you got it done! I'll be doing mine this week sometime. I'm going to try and leave work early Wednesday if they come Ups so I can do themI didn't have to move the compressor. I did remove the entire engine mount on each side.
The problem on the driver's side wasn't accessing the bolts, it was trying to break them free. I think they were seized worse than usual. On the other hand, the passenger side was a piece of cake. Didn't have trouble breaking any of them free.
Used new gaskets and so far, no signs of leaks. The bolts are still tight, but I'll keep a check on them every few days. Might as well leave the fender liner out for now.
Finally got to go drive it around. It sounds so much better than OEM manifolds with gutted cats. The gutted cats gave it a tin can sound. Now it sounds mean again.
AFR is staying between 12.8 and 13.1 with my BD tune. However, I might still consider an UpRev tune. Sometimes when you stomp it, it feels stronger than at other times. Maybe that will smooth out as the ECU learns. If not, I'll go UpRev.
I'll post pics when I'm done, hell even a video of the sound and a video of a 0-60. I'm going to wear gloves thoughWhat!!? No headers install pics!!?? No busted fingers pics!!?? WTF!!?
L
Hope your install goes better than mine. :teethmastGlad you got it done! I'll be doing mine this week sometime. I'm going to try and leave work early Wednesday if they come Ups so I can do them![]()
I'm going to guess I can do it in 6 hoursHope your install goes better than mine. :teethmast
I'm sure it will though, with all the preliminary work you've done. As much as you've soaked the nuts, and loosened them, yours should be pretty simple.
Part of my problem was that I got a wild hair Saturday and decided out of the clear blue to do the headers. No pre-soaking with PB blaster or anything. :teeth:
I think I have a total time of 12 hours in the install. A drunk monkey could do it in 10 hours. So I figure you're looking at 8 hours or less.![]()
You forgot to calculate beer time..I'm going to guess I can do it in 6 hours45 minutes to jack up the truck, take off the tires and unbolt the exhaust. 1.5 hours to take off drivers mani and put the header on and tighten nuts. 1.5 hrs for pass side. 30 min to rebolt the exhaust. 30 min to jack down motor and put wheels on
**** that's less than 6!! LOL I'm hoping it goes like this^^^^^
