1 - 13 of 13 Posts
i was thinking about getting a set of headers for the ole titan but then i started to wonder if the headers gfor these trucks are like the headers for the older chevys meaning do you have to tighten the bolts every oil change
iof not then who has a decent set of headers
thanks....................................charlie
· Super Moderator
There are many members who have headers on their trucks, if you do a search you should be able to find an abundance of information. Good luck!
Looks like Charlie has been here way longer than us !!!!! LOL
Good luck Charlie...Can`t help with the header question....
stillen makes longtube headers, but they are not exactly street legal because they replace the cats, jba makes good headers, powerflowusa also makes good headers, you can search google for more or go to stillen's website to look at others
stillens long tubes dont replace the cats.. you just cant use the factory ones you will have to have new b-pipes made with high flow cats installed , not like this is a very hard thig to do if you are really serious bout going fast..
if the install is done correctly you should only need to check the bolts about 500 miles after the install was done to make sure they are still torqued properly
We rarely get a call or two from a customer that has this issue and it usually goes back to an improper install on the component itself
I like my Nismo headers a lot.
I can get NISMO headers installed by my dealer for $1,000. Is this price a little on the high end?
I would jump on that in a minute provided they are the real deal and you can trust the dealer to do it right because that is cheap installed.
I have an appointment on Mon. to get my passenger seat fixed. I will probably set up another appointment to have the headers put on.
Has anyone noticed a significant change by adding headers.
That is cheep. I was just at my local dealer and they had a sign Nismo 1500 installed. As far as retorque on the bolts, Like Brad said if you do it right there fine. I have had mine checked twice and they have not been loose
1 - 13 of 13 Posts
