1 - 8 of 8 Posts
I had to get another headlight and the filler piece doesn't fit worth a damn any suggestions would be appreciated.
What headlight did you get? Did you break any of the pins on the trim piece?
I haven't replaced my headlights but bought the truck second hand and my filler pieces stick out a bit on the outside corners of the headlight, where it bends toward the reflector. I'd love the suggestions too.
Also kitch, depending on what year your T is. Be careful with them. mine is an '06 and the parts that hold the clips/ pins are extremely brittle.
All headlight years are the same assembly, just the older ones have the clear parking light lens. Don't know why the trim piece wouldn't fit in it. I know they're dumb questions, but are you sure you're using the correct side for headlight and trim? Just trying to narrow it down. Pictures of how it doesn't fit would help.
Did anybody every figure out where to get these? I just changed headlights today, and a couple of these clips cracked, leaving the filler trip at the bottom of the headlight loose. Thanks in advance.
1 - 8 of 8 Posts
